sorry I'm new here please forgive me...i have 2005 Toyota Prado GX 2700cc..I'm facing a problem..my inside floor is getting very hot as i drive(or the exhaust)..no power lag or anything..its just getting hot suddenly..i checked with many mechanics here..they said my catalytic converter is faulty..they welded a used converter still its getting hot..i live in Oman,muscat (next to dubai UAE) ....please help :,(
Floor getting hot
It takes time to get hot..like I drive for 10 mins it starts getting hot..and I checked under the car I have both the shields (heat shield and my catalystic converter is also covered with a shield) but still gets hot..I don't know if it's normal and happens with all prados (check if your Prado passenger seat backside bolt get hot while driving) I check the the heat by touching the bolts rest is all cool...and I noticed my it's giving me less mileage now..and goes slow on the signals
...please help
It can only be a few things:
- cat/exhaust too hot due to engine issue, ie, excessive unburnt fuel being extracted (faulty sparks/not firing? cylinder issue? not sure...)
- faulty wiring or electronic device consuming large power drain
- interior heaterglen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
I'd start by removing/checking the sparks, replace the ignition leads, clean everything. You may find some clues whilst doing this. You could also have a weak ignition coil - but it wouldn't be entirely failed or the engine would stop (each coil runs 2 sparks/cylinders).glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
