Loud constant hum
    This sounds strange but the fuel return banjo on the top of the fuel pump has a small spring inside, stretch this spring so its about 5-6mm longer and put it all back together.
    The spring is small like a biro spring.
    Strange as it may seem this little valve causes a resonance/hum that appears to come from the passenger side footwell (RHD models).
    Takes about 10 mins and makes a huge difference.
    KZJ90 1-KZTE GL
      Can you pick which direction it is coming from.
      The only humming I have had in mine is from the roof rack Bar.
      The faster you go the louder it gets.
      It has a rubber strip to insert in the top of the bar for when the rack is not there.
      The sound it can make is really quite loud with speed.
      It makes a hum similar to the noise when you blow across the top of a stubby beer bottle.
      Hope you find it soon rattles and noises drive me crazy to.
      2001 3Lt Manual Diesel, Safari Snorkel, ARB Winch Bullbar, Hella Spotlights, 9000lb Warn Winch, Dual Battery, Couplertec Electronic Rust Prevention, Glind Hot Water Shower, ARB Front and Rear Air Lockers,Onboard Air Compressor, DP Chip, 40mm OME Lift, Steel Slider Side Steps, GME 3200 CB Radio, Milford Cargo Barrier, Extended Diff Breathers, Draw system and Fridge Slide, 40lt Engel Fridge, GPS with Wireless Reversing Camera, Rhino Roof Racks with Aluminium Tray, Awning and Drop down Table on Rear Door.
        Hi guys, we had a strange noise in our wagon so did some research and stretched the spring in the fuel return line and presto noise gone.
          Hi, I've a similar issue .... hum/vibration starts around 110kmph and disappears at 120kmph.
          Unbalanced shaft?
          VZJ95 Manual / DC5 Integra Type R / DC2 Integra Type R
