Cheers Auss. Think I will search around and check out some other oil. Funny you say that now I think about it and Im goind back 20 years I used GTX when it was around (dont know if it still is ??) as I remember my sisters corolla sludging up (but must admit she was very slack with servicing) and when I did eventually say to her give me some $$ so I can get the stuff for you I always used castrol and when I use to dump the oil I use to think jees this oil is thick but put it down to lack of changes. It may have been a mix of slack servicing and the type of oil that also sludged up quickly. Anyway Ill make sure next oil change to be honest might just use the genuine stuff from Toyota. I get is trade price anyway. Might put a flush through it as well to get rid of the magnatec (not that I use the flush's anymore) Im not convinced this flushing stuff is totally drained from the system. Oil obviously must sit in galleries and places so this stuff is trapped and my contaminate the new oil ?? What do you think of that ?? Do you reckon its possible that the flushing stuff is stll present even though I drain it over night ?? And would it be doing harm mixing with the new oil for the next 7k ?? Cheers Steve
Transmission flange keeps leaking.
Dont use the flush Steve, all the sludge will fall into the sump and get sucked up in the oil pickup tube, you will then loose all oil pressure and kill the motor, instead, use a higher quality oil and change it and the filter every 3 thou, for 5 oil changes (total 15 thou), this will get any sludge out of the engine. I may cost a bit to do, but it will save you more in the end.Originally posted by Steve M View PostCheers Auss. Think I will search around and check out some other oil. Funny you say that now I think about it and Im goind back 20 years I used GTX when it was around (dont know if it still is ??) as I remember my sisters corolla sludging up (but must admit she was very slack with servicing) and when I did eventually say to her give me some $$ so I can get the stuff for you I always used castrol and when I use to dump the oil I use to think jees this oil is thick but put it down to lack of changes. It may have been a mix of slack servicing and the type of oil that also sludged up quickly. Anyway Ill make sure next oil change to be honest might just use the genuine stuff from Toyota. I get is trade price anyway. Might put a flush through it as well to get rid of the magnatec (not that I use the flush's anymore) Im not convinced this flushing stuff is totally drained from the system. Oil obviously must sit in galleries and places so this stuff is trapped and my contaminate the new oil ?? What do you think of that ?? Do you reckon its possible that the flushing stuff is stll present even though I drain it over night ?? And would it be doing harm mixing with the new oil for the next 7k ?? Cheers Steve97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Cheers Crooza will do. Im trying at the moment to find out who makes the Toyota oil, doubt it comes from Japan.....Actually might put up a post and see if any one on here knows, asked Toyota and they just said its there own ??? I doubt it but maybe true ...Cheers SteveFace lift 150 Prado V6 auto. No mods yet
Caltex are the manufacturers of Toyota lubricants.Originally posted by Steve M View PostCheers Crooza will do. Im trying at the moment to find out who makes the Toyota oil, doubt it comes from Japan.....Actually might put up a post and see if any one on here knows, asked Toyota and they just said its there own ??? I doubt it but maybe true ...Cheers Steve2011 150series GXL
Fair dinkum Wooley ?? might explain why the wifes toyota goes quit dark. I drain it every 10k use genuine filter and I use the toyota oil specifically for the VVTI. mmm now I will have to check out other oils that are compatible with the VVTI for both our cars...... Cheers SteveFace lift 150 Prado V6 auto. No mods yet
yep; oil, grease, handwash.. all Caltex.Originally posted by Steve M View PostFair dinkum Wooley ?? might explain why the wifes toyota goes quit dark. I drain it every 10k use genuine filter and I use the toyota oil specifically for the VVTI. mmm now I will have to check out other oils that are compatible with the VVTI for both our cars...... Cheers Steve2011 150series GXL
I'll think you'll find that the Totota oil you buy in the black container will be a mineral based oil. Mechanics I have spoken to from different dealerships say at best the manufacturers oil will be a semi synthetic. It's all to do with cost. I used to take my own oil to the dealership to be used in the change (Mobil 1 at the time)
