overdrive indicator blinking
  • overdrive indicator blinking
    hi guys,
    need your info, my overdrive indicator is blinking ib my dash on my Prado 90. fyi overdrive button at the auto gear shift is On. any ideas causing the blinking?
    Prado 95 3.0D Turbo Auto Series 1997, 285/70/16 Bridgestones AT 694's on 16x8 rims
    That indicated an error on the gearbox computer. Plug a scanner onto the gearbox's plug....
      where does the gearbox plug located in 1997 Prado TZ? I has no obd2 plug though. any idea how to find gear box plug on this model if?
      thanks in advance
        Dont need a scanner.... goigle toyota transmission fault codes and how to retrieve them
        You just bridge 2 wires in the diagnostic plug to entre read mode, the od lamp will then flash in a numbered sequence
          its flashing like 26/62 , I dont know exactly. what does this code stand for ?
