Rear diff locking
  • Rear diff locking
    It is been difficult to lock the rear diff on my -96 KZJ90. Diff lock light keeps blinking.
    Last time it was locked althoug light blinking. And after I turn the swich off, light went off but rear diff was locked (with 4HI, too!)
    After switching it on and off many times forward/backward at low speed, it engaged and start to work better. Still it takes very long time before blinking change to continuous.
    I think it cause of lack of using. It works better if I have used it regularly. Is there any easy way to fix this problem?
    [size=1]
    2007 FJ Cruiser 6M/T[/size]
    Problem solved. The quilty one was the motor, it was corrosied to crap.
    I was lucky and found a good used motor with same part# with very reasonable price.
    [size=1]
      Ahhh.... we don't have those electric factory rear diff locks in Australia!
      On that note, does anyone know if the Jap 90 series prados have the same rear diff as the Aussie 95 series prados? I want to get one of those electric diff lockers. Would it fit in? What's my diff ratio? (Trans / axle code A343F A02A).
        Why
        Why? so it can corode. Park on concrete,go to full lock,select FWD,now do circles and listen, here that screaming,thats your tyres waisting away because your diff is locked. No point in locking it twice but each to his own. :roll:
          Well at $1400+ fitting for air lockers per axle plus the the price of the compressor, its a hell of alot cheaper. I see your point Carrot.
          97 Vitara 1.6 JX Day Tripper(550klms range), 98 Prado V6 LPG GXL for Touring (1400klms range), Offroad Cub Camper for Overnight.
            I think it is. But axle housing need to modify a little: http://www.4x4wire.com/toyota/tech/electric_locker/
            You can buy the 3rd member with locker here: http://www.inchwormgear.com/store/produ ... ucts_id=38
            [size=1]
              KZJ90.Great picture,wish I could do that on my computor,but alas I am not in that league as yet..... 8)
                Re: Rear diff locking
                Hi all
                This is my first post but have you ever heard of a lokka by http://www.4wdsystems.com.au/ I think they are $600 but you can only get one for the rear diff.I don't have one yet i would like to hear if some one else has one and what they think.
                2000 RV TD With lots of suff
