Auto won't change into overdrive
  • Auto won't change into overdrive
    Hi guys, I have read through all the posts and was unable to find any like the problem I am having with my 96 3litre auto.
    It started the other day on the open road cruising along at 100km, revs sitting on 2200 then all of a sudden it jumped out of overdrive - revs went up to 3000 and would not go back into overdrive. Stopped to get a few things from the corner store then carried on home, wagon was fine for a few km's then it started again.
    Took the Prado into town last week (130km) and it drove fine. Got the transmission serviced then headed back home and then it did the same thing again after about 30km's or so so carried on on my way home and after about another 30 odd km's it went back into overdrive.
    I talked to the transmission people and they said it could be the transmission computer that is faulty and that they could fix it for about $350-400.
    Has anyone else had this problem?
    I assume you have a diesel? If so being a 96 it's a series 1 90 and has cable accelerator ... Not too familiar with the early ones but they are very similar to the KZN130 surf , same gearbox same injector pump , they used to have a lot of problems like this , there is no trans ECU just one main one
    All the surf guys reckon they put new capacitors in the ECU an it fixes it ! Speed sensor can have an effect also
    Try searching on the surf forums for cap ECU repair and surf auto faults
