Noise when traveling over 65Km/h
  • Noise when traveling over 65Km/h
    Hi all,
    I'm new to this forum as this is the first problem I've had witrh my car.
    A 97 Prado 3.4 V6 auto on petrol and LPG.
    Recently developed a noise which I think may be transmission based.
    When I go over 65 Km/h it develops a humming noise which gets louder when I go faster.
    I've also noticed that when I go over any dips and undulations in the road the humming gets louder and deeper, almost metalic, at the bottom of the dip, almost pulsing as the suspension is compressed then when the suspension is normal again it goes back to the previous hum.
    I've checked the gearbox oil, which was low so I topped it up to the correct level, it's quieter now but the hum is still there a little and the deeper noise is definitely still there when I go over/into a dip in the road.
    All the suspension bits and pieces are in good order with nothing worn like bearings etc. on the steering, ball joints either.
    I've read lots on here this afternoon and, please correct me if I'm wrong here, but the advice of others with similar issues seem to point to either rear propshaft UJ or Transfer box issues.
    I can do the propshaft easily but have never attempted a transfer box removal/repair.
    So, am I heading in the right direction with my prognosis? Or barking up the wrong tree?!
    Look forward to hearing news from those in the know.
    Many thanks, Jonneeb
    How are the fluids in the diffs and transfer case? Also any play with the wheel bearings?
      Hi,
      No play in the wheel bearings, will check fluid levels in the diffs and also the transfer case next.
      Also, I will check for any free play/excessive backlash in both propshafts too.
      Cheeers,
      Jonneeb
        hi and welcome jonneeb , is your car lifted ? I have seen some where the rear prop shaft comes very close to the stone guard on the sub tank , may be worse if the stone guard has had a bump towards centre/prop shaft .
        Other than that I would say a bearing somewhere in the driveline
        2018 GXL 2.8 1GD,
          Hi Brissy,
          Thanks for the welcome.
          I don't think it has a lift kit, if it does it's only a small one, there's also no evidence of any off roading or bump damage underneath anywhere so, unfortunately, I think I'm going to have to look deeper into bearing wear etc.
          Still need to check the diff levels and the transfer case oil level too, just no time at the moment, hopefully I'll get to it before it develops into anything worse than a noise!
          Thanks for the advice, I'll let you know what I find.
          Jonneeb
