I fitted mine into the bottom hose to my cooler, but it needs an earth to make it work
Thanks for the reply stu.
Can i ask where/what fitting you got?
Was it an inline hose fitting fitted to the inlet side of the cooler?
Not sure what type of fitting i would need.
I did see a youtube video of a dodge ram, where the lower side of the transmission had a bolt removed where the sensor screwed in.
Not sure if Prado's have these.
Yes. I have a separate aftermarket cooler, made up an inline fitting and T pieced the temp sensor into that. Then I realised I needed an earth doh so I just ran a short wire to the chassis.
I did look at the OEM sensor, it's just next to the trans box. It just sends a signal to your dash light to warn you if the oil gets hot, but I struggled to get a spanner on it! I was going to insert my temp sensor into the existing t piece but became too hard basket.
