Torque Converter Lockup upgrade and Nomad Valve Body upgrade
    I've just had a Nomad valve body fitted to my 2011 Prado. The Prado has 180,000km on the clock and has done quite a bit of towing, both here in Oz and in New Zealand. It is fitted with 265/70/17 tyres. I was looking for something that would "tighten" up the gearbox and I think I've found it. I've only driven it around town so far and there is a noticeable difference in the amount of throttle required for day-to-day driving. Very light throttle applications result in faster than normal acceleration.
    The gear changes are now noticeable. You get a gentle nudge at every change. I like the fact that I now know what the gearbox is doing. I was a little surprised that it engages second gear almost as soon as you get rolling.
    I'll provide a further update once I've done some highway driving and again after I've done some towing (light weight off-road trailer). If I remember I'll also provide an update after I've done some off-road driving. I'm hoping the car no longer runs away downhill while waiting for insanely slow gear changes in low range.
    Edit: I've had the AT fluid changed every 80,000km and they said that it was very dark and burnt. The installer used genuine Toyota transmission fluid and does not recommend using anything else.
    luke29ermtb
    Lurker
    [COLOR="#A9A9A9"][B]2011 Prado 150[/B]
    SmartBar, Kings springs, Bilstein shocks with a ScanGuage on the way.
    Occasionally tows a 14.44 Jayco Expanda Outback[/COLOR]
