Where to get new remote internals
  • Where to get new remote internals
    When I bought my 90 series it came without a remote I have read up on it and it did come factory with keyless entry. I have been searching high and low for an after market key, surround and internals and havent had anyluck at all anyone else had this problem please help. Ta Mass
    1999 Prado Snowy 265/75/16 Mickey T's ATZ 4RIB, Uniden 80 channel CB, 2" EFS with PolyAirs, PP Rear table, JVC Bluetooth deck.
    Your best bet is to install a complete after market system that will basically actuate the driver's door central locking switch. You would be up for big money to get a new transmitter to work with your existing receiver.
    Out of interest, how do you know your Prado is fitted with remote central locking? I don't know about snowy's but GXL's didn't get remote central locking till 2000.
      My mate has a snowy also and I saw the specs for the snowy the keyless entry was a big part of the mods for the model. Wonder how far i have to go as in replacing the after market system.
      Ta Mass
        The sinple answer is not far, the problem is the expense. If the the Snowy cam ewith factory central locking the you are as close as your nearext toyota dealer to getting your remote, it won't be cheap though. A after market remote system will be about 50$ with two remotes from somewhere like ebay and install youself. If it is already to go and and factory fitted, give toyota a try but be a ware of the cost, Good luck Ian
          yes the snowy definatley came out with remote - my remote packed in a couple of years ago didnt bother fixing allways used key to lock
            Here's an easy fix.
            http://www.ebay.com.au/itm/Car-Keyle...item2a1119143d
            More on ebay.
            http://shop.ebay.com.au/?_from=R40&_...All-Categories
              The first one suggested by Willade above is the one fitted to my 98 RV and works great, it is even cheaper now, bargain.
                Cheers Lads might have to give the http://www.ebay.com.au/itm/Car-Keyle...item2a1119143d a go cant be that harder job...can it ahha. Havent been able to get to PP for a bit good to be back =)
