Hi Guys, I have a 98 prado with 1KZ-TE engine, done 210,000 k's. My engine management flashes on for about 3-5 seconds and then goes out. It only happens on the open road when going down a steep hill with your foot off the accelerator and the hill is steep enough to hold you at the same speed. ie you dont slow down when you button off the gas.It doesn't happen every time.
The two fault codes that come up are:
code 13 - RPM2 (NE) sensor signal fault and
code 14 - Timing control system problem.
There is no noticeable difference in the vehicle or no smoke or anything.It starts and runs perfectly. Any thoughts??
