Prado 90 flasher unit
  • Prado 90 flasher unit
    Hi, can anyone help me, am look where i can find the flasher unit on my Prado 90, 1999, thanks in advance
    Hey Mate, I'm assuming you are talking about the flasher relay, which is located in the fuse panel under the dash, I have highlighted it in the picture below, Cheers
    99 3.4L Auto - Snowy Limited Edition - 2" Tough Dog suspension lift, Wholsale Automatic's Nomad Valve Body with Manual Lock up Torque Converter Switch, ARB Bullbar with Narva Ultima Driving Lights and Winch, 265/75R16 Cooper ST MAXX Tyres, Pacemaker Headers, Custom Rear Exhaust, GME UHF in Custom Dashpod, Dual Batteries and Monitor, Rock Sliders, Cargo Barrier, Safari Snorkel
      If you see that big box on the right of that picture the flasher replay is mounted on the back of it , you will need to unbolt that fuse box assy to get to it
      By the way Toyota don't have any in Aus atm , i tried to get one the other day
        yeah mate i have replaced that with an led flasher unit but still flashing to fast
          Check for blown globes which will cause a rapid flash. Also upgrading globes to leds will cause the same problem. Ken.
          Ken
          3.4 GXL man 1997 petrol / gas, BFG mud tyres 265 75 16, front and rear camera, Jaycar 6300Lm LED 6.5" D/L * 2, 15W LED reversing/work light, diff breathers, 42mm lift, Rear Anderson plug, Dash cam, and way too much recovery gear for one vehicle to carry around. No more HID headlamps. No more Narva D/L.
