Cabling Size
  • Cabling Size
    I am putting in a dual battery system in my 2001 TD. The cabling run is about 6metres. I will be running a fridge (approx 2.5-3 amps per hour as a over estimate) with another three sockets rated at 10 amps, a ARB air compressor and some USB charging points.
    How do I calculate the cabling size for the cable run I need to run these accessories?
    As a practical matter I prefer to err on the side of caution and would go up a wire size rather than down.
    Use the Redarc calculators below to determine your needs:
    http://www.redarc.com.au/handy-hints/
