I have now finally got all the stuff to fit the dual battery system.
Every other circuit I run has a fuse fitted of varying size.
Do I fit a fuse to the cable between the two batteries, if so what size (I am using a Projecta 100 amp isolator)
I am running power to the rear of the Prado, in the rear is the fridge, LED lights and ARB compressor, what size fuse should I run? due to the length of the run I am using 2B&S cable so it is very thick (35mm squared)
any suggestions would be appreciated or do I use circuit breakers?
Thanx in advance
Gerry
Thanx in advance
Gerry
