Name these plugs...
  • Name these plugs...
    Had the centre console out to replace the gear shift lever bush, and fix the rattling dash trim, and noticed these two plugs hiding there.
    Anyone know what either of these are intended to be plugged into? My Prado is an RV, so I expected to see some empty loom plugs due to the limited factory spec, but these seem to be in a bit of an odd spot.
    Both photos are taken from front passenger foot well, looking toward the front of the console (in front of the shift levers).
    I'd say ABS Decel Sensor and centre airbag sensor
      I'm guessing Steve is the top one and Janice is the bottom one.?
        Thanks Toopy.
        Slow clap for you MidLifeCrisis :P
          The top one is for rear ac
          The bottom im unsure but it isnt a decel sensor there under the center consloe and haveca different plug
            well there you go, is yours man or auto?
            might be for shift lock and second start buttons
              Originally posted by teho View Post
              Thanks Toopy.
              Thank you, sometimes I can't keep up with the fast ones...
