OBD2 can't connect
  • OBD2 can't connect
    First off, I have a 2000 model, 3.4l V6 Prado.
    I have had a high idle problem and want to check fault codes. I have tried connecting two different scan tools but they fail to connect. I have connected both scan tools to a mates Prado and the connect no problem. I have checked the OBDII 7.5 amp fuse under the bonnet and it has power both sides. Has anyone had this issue and managed to sort the problem?
    Cheers, Biff
    Hi Biff,
    What year was your mates Prado, is the 2000 model ODBII compliant from
    the quick check I did it would appear it isn't?
    LeighW
      His was an 06. Thanks mate, I didn't think to check on that :-/ doh!
        Wonder if this would help
        http://www.pradopoint.com/showthread...n-M-OBD-Prados
          No Australian Prado 90 series is OBD2 compliant. Even the early 120s are not.
          Michael and Kelly
