Kdj95 obd
  • Kdj95 obd
    Howdy!
    Did a quick search, with no useful results.
    I have a 2001 Prado KDJ95 with 3.0 D4D engine. It has "diagnostic" plug in the engine bay and some other plug in the drivers side, below the steering wheel. I assume this is a OBD port?
    Is it a OBD or OBD2 port? Can i use ELM327 bluetooth dongle with torque software with it? What kind of info is the dongle able to read from there?
    Thanks in advance
    Anyone?
      Mate, most of us are in Australia so it is quite hard to give worthwhile advice on vehicles in Finland. If you have a read up on Wiki and do a google search of OBD use in European vehicles it should give you most of the info you are chasing. I would guess that the plug in the drivers side of the cabin is an OBD port, but a look At Wikipedia will show you a picture of a typical OBD port So that you can compare and be 100% sure before you buy the dongle. If it is indeed an OBD2 port the ELM327 dongle will work. I have one on my 08 D4d and it gives fairly basic engine data out via my iPhone. The best thing is to find the App you intend using with the dongle and then 'view' before you commit to purchase to see exactly what information the app will give you. To be honest I am fairly dissapointed in mine as the information available through my app is basic, I tend to use Techstream for any serious monitoring of engine performance. I hope that this is of some help.
        Ok, i need to look into this. thanks anyway
          No problem. If all else fails contact Toyota Finland or Toyota Europe they should be able to confirm dates for OBD2 introduction for your vehicle. Good luck.
            Hi, did you ever figure this out?
