Hi all,
Have an issue with the ‘door open’ indicator (red light on the instrument panel) in a 90 series GXL.
The red ‘door open’ indicator light displays incorrectly (when all doors are definitely shut), in the following circumstances:
In both of the above cases, pressing ‘lock’ on the remote central locking fob locks the doors and the red ‘door open’ indicator light goes out.
Info that might be helpful;
The remote central locking is a Viper 211HV installation (I had this done as I’m not an auto-electrician by any means!) - the issue was not present after the installation was initially done. Also to note, if a door is actually open and I press ‘lock’ on the central locking fob, the doors lock but the red ‘door open’ indicator correctly stays illuminated.
Any ideas or suggestions would be great.
- Immediately after unlocking the car’s doors via the ‘unlock’ button on the remote central locking fob - the red indicator will remain illuminated until I get in the car, close the doors and turn on the ignition to accessory or start.
- After driving, as soon as the ignition is turned off (before any doors are opened).
