G'day all,
If this as been answered somewhere before, please forgive me. I have looked, but the answers seem to allude me.
Some very brief details....
2000 model Diesel, and not much done to it just yet The dual battery was installed by me, so I could have made a beautiful mess of the whole thing.
In short, this is a charging question. So, I will ask without the detail, as someone may know the answer without having to go into it all. Is there a voltage sense wire that controls a switching circuit for the alternator? And which wire is it?
In long. I installed a dual battery system (according to the diagrams supplied with the solenoid), and all appears to be working correctly (which may sound odd, but will hopefully make more sense as I go on). The crank battery and auxiliary are isolated, and remain that way until the crank battery reaches the voltage to close the solenoid. I know this all works, and I know the alternator is no dead because when I connect the accessories back on to the crank battery, the alternator starts charging, and after the voltage is reached, the solenoid closes connecting the auxiliary battery. This leads me to believe I need to connect a sense wire to the cranking battery.
The only thing that I can think of is that I need to flatten the new auxiliary battery so that it reaches the point where the charging circuit is started. I only see this could defeat the purpose of having an auxiliary battery, as if I do a lot of starting/stopping in a short period, then I have he potential to flatten the cranking battery before the auxiliary is at a point needing charging.
I hope that all makes sense, as I am off work with lots of pills floating around my head to try and make it a little clearer. Anyway, here are some pictures if people are interested. And before someone says "That box isn't waterproof because you have put holes in it", well I wasn't going for a waterproof box, I just needed a barrier to stop the risk of someone (most likely myself) shorting the cables to ground. I don't like vaporising tools, or setting vehicles on fire.
Thanks for looking, and helping.
