Hi, today the pass side window went down, but not up again. Took off door card etc. And tested wiring, all seems to make some sense, power delivered when switch operated each way.. so left with the motor being deaded.
Rang around locally (Adelaide) and found at least 1 used for $125...
Before I go and spend money on a used one has anyone else found a source?
I can't really believe that the motors are designed differently from left and right side land cruiser... Or even maybe the same as Rav 4 (year????) Etc.
Any thoughts or knowledge please?
