Alternator Charge
  • Alternator Charge
    Hey there, does anyone know what voltage their alternator runs at on idle in drive with the headlights and air con on
    Cause i cleaned out my alternator cause my redarc keeps cutting in and out due to the voltage from the alternator low at idle
    and just wondering what other cars rev at on idle in drive
    help please
    2002 Vx Prado 95 series. 5vz-fe Motor. 2" Lift. Ironman Springs, Constant load in back. Dura Shock Shocks all round. Yokohama AT-S 265/75 R 16. Rhino rack bars and rhino rack cage. Long handle shovel holder. Tent pole Pipe. Awning. 240 Blitz lightforce lights. TJM premium Alloy Bar. Custom Rear Light. Uniden 400sx UHF. In dash dvd touch screen. Splits In front speakers. Custom rear draws. Canvas Seat covers all round. Custom dual battery cradle. Projecta dual battery system. 40l engel fridge.
    Re: Alternator Charge
    Mine's at about 12.6V when idling with aircon. Upto over 14V when driving.
      Alternator charge rate shouldnt drop down below 13.5volts on load or else you have a problem.... Above 14volts is more ideal but with all the acc.. with install in our 4wds, anything above 13.5 volts would be acceptable...
        Yep I made a mistake when I said 12.6V, wasn't thinking properly. Shows 12.6V when the engines just turned off. When idling say at the lights with aircon and stereo on I have around 14. It slowly drops down to about 13.6 but that takes a fair while when the cars running...
          Hi,
          If you wish to increase the Alternator output voltage a little to stop the
          redarc cylcing you can read about my Alternator Voltage Booster
          in the 120 electrical forum.
          LeighW
            when i start my prado i get 14.3v then when it warms up it sits anywhere from 13.8 -14.2v
              Hi Fellas. To anyone still interested in alternator voltage norm's.(Alternator 215,000 km never been touched, battery N70 3 years old) My Prado (1KZ-TE) battery reads 12.6v stone cold in morning before start-up. (this after coming home late at night with 3/4 hour highway driving) 14.17v immediately after start-up with engine idling. 14.2v with engine at anywhere between 1200 - 2000 RPM with all lights and accessories maxed out. I have fitted good fat (and I mean starter cable fat) earth cables from battery to block under alternator, head above compressor, body behind LH headlamp and body above fuse panel on RH side. Talk about fast starter turnover speed and good lights Trev! If I was to run a fridge down back I would also run a bloody big earth down there. Can never have too much copper brother. Cheers, Derb.
                Hi Derb and a great bit of feedback.
                Do you know what is the size of your alternator to cranking battery cable is?
                  Hi drivesafe. Alternator to battery cable is stock as fitted ex - Toyota. I haven't fitted a larger alternator, have no voltage drop and the cable does not get hot so no point in going larger. (if it ain't broke - don't fix it) If I decided to upsize, yeah I would then have a look at it. It is probably time I did the brushes and bearings though. Cheers.
