Dash board noisy
  • Dash board noisy
    Hello All . i recently have bought a prado 90 series grande 217000 on the clock . after driving it for a while i have noticed the dash making a lot of noise especailly driving on patchy road . i have checked the tyre pressure .all ok . i showed it to an electrician he advised the brackets inside may be broken and advised getting a used dash pad from the reckers would not help as Grande has a passenger airbag the used dash may have a faulty airbag ......... and to fit it would almost cost 1500 just for the labour
    i went to a different person .he advised open the dash and put some sponge under the it and should be ok
    Please advise if anyone has an idea.what can be done to reduce the noise
    thankyou
    MAX
    90 series, Air lockers , 2'' TOugh DOG Adjustable's (very happy so far), TJM Bar , 9500 lbs OX winch Plasma rope,TX3100 UHF radio, Mickey's MTZ , ARB Air compressor,
    Re: Dash board noisy
    Hi,
    My Prado KZJ95W has just come back from the workshop.The guys plugged in some sponge and fitted extra brackets where needed. The dash does not rattle at all now.
    I also replaced my front struts aand repaired the strut mounts too.
    Ekendra (4S7EF)
    Ekendra (4S7EF)
    1997 Prado 1KZte/KZJ95W
      Try this from Prado4x4, its mostly aimed at reducing the movement of the dash but may also help with the rattles.
      http://members.iinet.net.au/~jah/4wd/DashFix.doc
        On mine I installed a bracket both sides, and found two loose nuts behind the speedo. The clips appear to be ok, I'm happy with the result.
        02 TD Auto Advantage.
        Light force 140's,Dual batteries with redarc,Volt meter for aux.battery,300w inverter,Rotronics
        low coolant alarm,Kings springs,70 Ltr evercool fridge freezer,Rear power outlets for fridge,
        Garmin quest GPS,Fire ext,Beaudesert exhaust,Removeable rear floor,GME TX4200 UHF,
        Alloy bar,Tow bar.
          Hi Mate, Can you please advise what it cost and who carried out the dash repair? I've got the same issue and its frustrating??
            I made my own brackets, just cut two pieces of galvanised steel into a square and drilled a hole in three of the corners. I started on the passenger side (which took the longest) by removing glove box to access behind the dash and then did drivers side which only took about 20 minutes.
            I didnt take any photos, but have attached some from someone elses fix (off LCOOL) to give you an idea of whats involved. Its pretty straight forward and stops any movement of the dash completely. I did mine several years ago and havent had any problems since.
            Passenger side
            View behind passenger side of dashboard
            Finished product
              Thanks for posting that Rainman.
              Hoping to do this mod also in the near future!
              I noticed that the document link is no longer working... would you mind emailing that through to me ([email protected]) or uploading it again if possible?
              Thanks!!
