Diesel sumps
  • Diesel sumps
    Im doing a 1KD conversion in my VZJ95 , are the 120series 1Kd sumps the same or able to fit ? The diesel sumps from a 95 are proving hard to find .
    From what I've read a 1KZ-TE sump is required on the 1KD you are converting.
    Matt- 2001 GXL Turbo Diesel- ARB Deluxe Bar, Tigerz11 10 000lb Winch, Brown Davis Underguard, IPF 800XS, GME TX3400, Custom Draw System, LT 265/75r16 BFG All-Terrain T/A's, Lovells and Konis, Unifilter. My rig [url]http://www.pradopoint.com/showthread.php?24975-Reidy-s-2001-GXL-95-Series[/url]
      But is the 120 chassis the same in the engine bay as a 95 series?
      The bottom end is more or less the same from kz to kd apart from pistons
      Ideally a 95 series sump would be perfect ! But there's none in Perth
        Hi Scott,
        You will need to use the sump and mounts off the 90 series 1KZ.
        If you do a search you will discover this conversion is well covered in a couple of threads already.
        In particular one done by Pradofreak if my memory serves me well.
        Besides it is always a good idea to try searching for information before starting a new thread.
        Lee
          The reason you require the KZ sump is due to the diff and crossmember arrangement if memory serves me, but as Lee has stated, Pradofreak has covered this in his thread "the successful 90 series D4D conversion".
            !! Last time I trawled through this thread I didn't see it !! Although I wasn't looking specifically for sump issues ...
            Ok so the 120 dosnt fit ... Dose that mean no one has tried to make it fit or is it just far too different to fit ? Can it be modified to work??
              http://www.pradopoint.com/archive/in.../t-12169.html?
