1KZTE 3L TD engine - any hints re. ppl who know prado's?
  • 1KZTE 3L TD engine - any hints re. ppl who know prado's?
    Hi prado lovers
    What I'm chasing is info (or contacts for clued up people) about the 1KZTE 3L TD engine, found in 90 series and early 120 series prado's.
    I sucked mud through my 90 series engine a few months back (clever I know) and have had to clean out the intake tubes, turbo, intercooler, intake manifold, fitted a new head, new glow plugs, rings, bearings, head gasket, hoaned the cylinders and got the injectors serviced (new nozzles, etc). Since the rebuild it is a pig to start when cold, and blows smoke and misses like you wouldn't believe when cold from idle up to about 1200 - 1300 rpm.
    Once engine is up to temp, no probs at all ??????????
    We've done compression tests, taken the injectors back to get re-tested, checked the fuel pump timing, checked out all the intake system for blockages, checked all electrical connectors are ok.
    We've done about 12000 k's since rebuild with this being our only thorn.
    We believe it may be a fuel pump issue but aren't sure and neither is anyone around here who claims to be a mechanic. It also seems wierd that it would be the fuel pump, given that it was only removed during rebuild then refitted??
    Most diesels have mechanically controlled fuel pumps, but not the prado!! Toyota in their wisdom made them electrically controlled, so finding a cluey person is difficult to say the least!!!
    Our local dealer simply looked blankly in reply to any of my questions. :?
    If anyone has had similar probs or has any info i would appreciate it and then some!!!!!!!!!!!!!!
    Oh, and don't worry.................................I ordered a snorkel!!!!!!!!!!!!!!!!!!!
    '00 KZJ95 Prado GXL
    3.0L turbo diesel, 5 speed, white, BFG All Terrains, TJM steel bar, custom built side steps/brush rails, Pioneer headunit, GME TX 3220, dual batteries, 600W hardwired inverter, nightvision lights, rhino racks.
    Have you checked the glowplug preheat system? Could be one is faulty. I had previously a Toyota 2H 6 cylinder Diesel which had similar symptoms. In that case I think it was only 3 were open circuit but it stopped the engine from being started at all. You may have only one faulty...either electically or mechanically....and that is making it hard to start.
    Not knowing the effects on the 1kzte...it may be that if the whole system is not working you may get your symptoms. I suggest an inspection of the electrical cables, the associated relays etc.
    Richard
    2011 GXL TD Auto Prado Silver
      Ok. Ta.
      I'll try that avenue out.
      I appreciate your time bloke!
      Mick
      '00 KZJ95 Prado GXL
        Check the glow plug fuse.
          Maybe - not enough diesel served to the engine.
          I solved the same prob :
          Check/change diesel filter (clean out water inside)
          .... some those difficulties comming with poor exhaust conditions...
            Mick,
            My money would be on air in the fuel (overnight and small air leak with fuel draining back). Does it make any difference if the weather is hot or cold?? 1 glow plug down should not make to much difference on a summers morning with the engine temp already at 25c (maybe a slight misfire for a few seconds). Hope this helps
            Cheers Ben
            2008 Holden Calais 6ltr
              Mick...any answers yet to your problem?
              Richard
                Game over, problem solved!!!!!
                Was the fuel pump in the end.
                Took 5 hours to do the change out and away she went, so I'm cheerin'! :lol:
                Thanks to everyone who weighed in with their advice, etc.
                The bride is happy again so all's good.
                Over and out.
                Mick
                '00 KZJ95 Prado GXL
                  May have been contaminated when your engine was rebuilt?? At least it is sorted now :lol: :lol:
                    I wonder where That fuel pump Came from ta !!!
                    Glad my Pump solved your Problem !!
                    its was well loooked after !!
                    pradofreak
                    90 series Prado with a D4D purring under the Bonnet !!, Catch me if you Can !! taa
                    Shes Loaded with air compressor,
                    2in top dog adjustable shocks and coils, 31 in tyres, Arb Bullbar and Warn winch, cargo barries and more to come when the Interest Rates comes down
                      Yeah freaky thanks for that lifeline mate, you're a legend and now with the D4D carving up the tracks it would seem that 'legend' just doesn't quite cut it! :lol:
                      Mick
                      '00 KZJ95 Prado GXL
                        haha !! she,s running beauitifully
                        well Good Luck !!
                        8)
