Not sure if this is the right place to post this.
I have a 3 litre diesel.
I usually fill both tanks then run the small tak out first then the main tank.
At its last fill I activated the switch to the smaller tank and the green light came on on the gauge, however the fuel continued to be taken from the main tank.
My first thoughts are that there is a problem with a relay or something similar. I have looked up my manual and there is a fuel return solenoid valve and a sender and pump in the circuit.
Has anyone else come across this problem and can help please?
