Diesel Fuel Tank Cleaning Process?
  • Diesel Fuel Tank Cleaning Process?
    Hi all,
    Pardon me if this thread is already discussed.
    I want to know if anybody went through the process of diesel fuel tank cleaning on his/her prado?
    diesel tank often gets rust, water and gunk inside. So this process should be included in periodic maintenance.
    what you guys suggest about this ?
    Not saying it cant rust but diesel is an oil and with constant splashing around coating the insides of the tank i cant ever see it rusting
    Petrol yes
      Originally posted by Jamal albalushi View Post
      Hi all,
      No. They generally stay clean.
      No diesel tank does not get rust. No it's not periodic maintenance, it's a repair if you unlikely get water & algae.
      I suggest you put a 7mm flow reduction plate in for your egr system & get a fresh set of injectors, no power upgrades.
      Then drive!
        Actually I was going through this youtube video and I thought does my vehicle worth this process to remove biocontamination, sludge and algae from tank.
        https://www.youtube.com/watch?v=QnUYsKZ9Y8Y
