Runaway Diesel
  • Runaway Diesel
    Hi all.
    Has anyone experienced a runaway diesel in a Prado? Just wondered how common this is in Prado's with high km. I know the 1KZ is a tough motor but is it immune to runaway? From what I have heard in other vehicles it is not a pleasant or cheap experience. :cry:
    Regards
    Re: Runaway Diesel
    I don't recall seeing anything about this on the forum, however, I can certainly relate to the "runaway diesel" experience when I had a TD Jackaroo :evil: The thing accelerated (not a huge amount luckily) while driving along a main road & then the engine self destructed :!: :shock: :shock:
    Only had the thing for a month :!: I had bought it from a used car yard so they had to fix it under the statutory 3 months warranty Heard through the grapevine it cost them $8500 to repair :P
    Glenn
    Glenn
    2002 GXL 3.4 auto with BFG AT's, Lovell's/Bilstein suspension, ARB steel bullbar, winch, towbar, diff lock, air compressor, GME UHF & AM CB radios.
    [url=http://www.youtube.com/user/gh4wd?feature=mhum][b]Youtube[/b][/url] [url=http://www.panoramio.com/user/2941589][b]Panoramio[/b][/url]
      Re: Runaway Diesel
      Glenn
      Bet they changed the oil and put the wrong grade in which stuffs the injection timing.
      $8.5k is a cheap rebuild for a jack.
        Re: Runaway Diesel
        The 1kz runs a throttle plate in the intake which fully closes and cuts the intake air on shut down (for smoother shut downs). This would make it immune to becoming a runaway engine. No air = no burn.
        Mick
          Re: Runaway Diesel
          OT,
          ever heard and seen a 6V53 rev to destruction - it's quite impressive
            Re: Runaway Diesel
            I had a runnaway diesel in the Northern Territory years a go in landcruider, might have had something to do with when stopping for a roo, the fuel can fell off the roof rack and spilling half it's diesel on the bonnet....it stopped after a minute or two of revving out to the max.
            Mick W
            2002 90 series TX
            Turbo Diesel 3L
            ACT
              Apologies for the grave-dig but I think this story might be of interest:
              I have experienced 30 seconds or so of what I'm 99% sure was runaway in the 1KZ powered 90 series we just bought.
              Coming up the freeway out out Adelaide on the weekend I dropped back to 3rd to pull into a gap in the right hand lane. I got the revs up to around 3500 and when I went to change to 4th the engine took off towards redline as soon as I pressed the clutch in. After a couple of seconds of panic and a half dozen circles with the gearstick I found 5th and got the revs down again.
              The car continued to pull up the hill without me pushing the accelerator for another couple of hundred meters with pretty decent stream of grey smoke out the back before it settled down and went back to normal. I drove it home slowly without further trouble.
              When I got home I had a look under the bonnet. When I checked the dipstick I discovered the oil was at least 50mm over the full line! I have since taken it back to the dealership who we bought it from and who serviced it before I picked it up. They dropped the oil out and confirmed that it had at least a couple of litres too much oil in it.
              I ran it up over 3500rpm a few times on the same stretch of road tonight without it happening again so I feel pretty certain that what I experienced on the weekend was caused by a bit of oil from the overfull sump being blown out the breather into the inlet.
              2002 KZJ95R RV
                [QUOTE=Lucky Phil;346345]
                When I got home I had a look under the bonnet. When I checked the dipstick I discovered the oil was at least 50mm over the full line! QUOTE]
                That's is insane , they must have put 10L of oil in it, they will blame the apprentice for that.
                thanks for sharing the story with us.
                  [QUOTE=jayden;346420]
                  I rebuilt a Cat D6 once and at smoko went down town to get a custard tart (we had real ones in them days) and told the apprentice to 'fill it with all'.
                  Went to check it before start up and it flowed out the dipstick hole. You guessed it. Filled to the top of the rocker cover
                  My bad.
                    Here is a diesel that was over-filled with engine oil Lol
                    http://youtu.be/Fw2r_lIRgpY
                      I've also had a case of the runaway diesel in my old 4runner. Long story short overtaking a truck plus a very surpised roo equaled one rolled 4runner (I don't blame the truckie for not stopping as he probably never saw me) after an hour of righting the old bus I let it settle for 30minutes before starting it. It started well but had trouble holding revs untill I got them above 2k and then it just took off... I stalled it out in first once it reached 3500, scared shitless i waited another 20minutes before and it ran fine like it never happened. The 4runner was a rightoff (too much pannel damage) but it's out at the stations still being used as a runabout.
                      2006 GXL, D4D, White, Sovereign Bar with Winch, 265/70r17, 2" lift, Recovery Points, Max Trax
                        Yep. That's about the colour of the smoke I was seeing!
                        Lucky Phil
                        Lurker
                        2002 KZJ95R RV
