DIY LPG tuning
After reading from the LPG tuning gurus in these links, I now suggest leaving the converter (ie sensitivity and idle mixture) settings alone and only screwing in the large gas restrictor screw on the low pressure pipe just until performance is impacted.
http://www.performanceforums.com/for...DIY-LPG-Tuning
http://www.fordmods.com/post597545.html
Best to leave the mixture settings to a garage with an oxygen sensor to get them right. Perhaps the large screw at the bottom of your converter needs to be removed to let the sludge out? Again your garage should confirm. Let us know how you went.
