Fuel tank changeover solenoid
    Thanks ratsack
    Any chance you can post a shot of the guard?
    Seems like min is maybe missing the original plastic guard which maybe explains why it's been a problem...
    Maybe I can get a guard from a wreckers or make up a stronger steel one...
      Just got a couple of photos for you. Hopefully this helps us all out?
      This is from the passengers side looking under the car. The "guard" is there on the bottom;
      https://lh4.googleusercontent.com/-t...112_164600.jpg
      This is under the car, looking towards the front. You can see the "guard" at the bottom of the picture;
      https://lh6.googleusercontent.com/--...112_164659.jpg
      Let me know if the pictures don't work.
      [B][URL="http://www.pradopoint.com/showthread.php?30380-Ratsack-s-90-Series-Prado"]Toyota Prado GXL Kimberly - 95 Series - 3.4L V6[/URL][/B]
      [QUOTE=maulbeagle;469810]Have heard that the fuel consumption of the petrol engine is horrendous ?[/QUOTE]
      [QUOTE=amts;469812]Heard that a replacement D4D engine is horrendous [/QUOTE]
        yeah that's awesome... I'm obviously missing the OME guard from that area... thanks! might try and source one or replicate.
          Maybe it has something to do with mine being a GXL Kimberly? I dunno...
          What I'd do is get one just to use temporarily and then make one out of something stronger and also make it cover a slightly bigger area near that fuel solenoid. I assume with that cover, I should be protected enough to not have to worry about the issue you've had. If I do have it though, I'll report back here and also replace the guard with something bigger and stronger.
            Ok so new part ordered and received;
            Hopefully it's the right one!
            Getting it fitted Friday....
            In the meantime ill be looking for one of the guards from a wreckers (thanks ratsack!)
              I was under my Prado earlier and noticed it's even longer then I thought. It basically starts where my front bash plate finishes. It's just snapped in 2 pieces so I didn't realise. I want to get a replacement gaurd made out of something stronger but don't have the talent and don't think anyone makes one. :-(
                I had this happen to me sunday night driving on farmland. A bloody stick got caught up in there and ripped the hoses out and snapped off two of the plastic bits..Mechanic in town did a temporary fix to get me back to melbourne. But need a new one now..
                mrkrinkle, Was that the correct part you ended up ordering??
                96 GXL Prado 3.4L with 50mm HD front coils and MD rear coils with poly airbags, Bilstein shocks, 265/75R16 Federal couragia MT's, black sunnies, GME TX4600 UHF, ZCG 6.6db antenna, Narva 175 driving lights, 20" and 38" LED light bars, roof rack, Safari snorkel, ARB bar, Redback extractors and a custom 2 1/2" exhaust.
                  The original plastic guard is hopeless, any knock at all and it would be broken. My guess is that the original has been broken off when off road or it may have been when the fuel filter has been changed. Even if you do get the original ensure you build / get built a steel replacement. This post has reminded me that I have to replace mine. Well I can put that in the list of jobs that I have to do. Ken.
                  Ken
                  3.4 GXL man 1997 petrol / gas, BFG mud tyres 265 75 16, front and rear camera, Jaycar 6300Lm LED 6.5" D/L * 2, 15W LED reversing/work light, diff breathers, 42mm lift, Rear Anderson plug, Dash cam, and way too much recovery gear for one vehicle to carry around. No more HID headlamps. No more Narva D/L.
