Fuel consumption... Petrol 90 series only
    Re: Fuel consumption... Petrol 90 series only
    Originally posted by BirdMan
    Hi Newbie here :?
    I am new to the Prado ownership ranks.
    I was a little worried about fuel consumption before I bought a Prado (or any 4WD for that matter) however, I am ok with figures ranging from 12-15 L/100km for a stock 3.4 auto with no load in 50/50 conditions.
    I am a little concerned when after filling the 90 litre tank (with 72L after the light came on, that I have already used up 1/4 of the tank and only just hit 100km. I am no lead foot and have been very cautious but if the tank and guage are accurately calibrated, then I am expecting that this tank full will average out at 20L/100km which is horrific.
    This might not be the right thread to bring it up, but does the computer and auto transmission 'learn' from the driver, and can I reset it back to factory settings so it can learn my drving styles ? Can it be done without disconnecting the battery, because if I do that I will have to enter a pin into the Radio, and I don't have it (so wanting to avoid that little annoyance).
    cheers for any help/advice ops:
    Welcome BirdMan
    It's so hard to gauge the gauges I've thought what you're saying before but it never really calculates that way.
    If it does turn out to be 20lt however... I'd be searching old threads about improving fuel consumption as that's not right for a stock 90. Things like, clean air filters, MAF sensor etc...
    Cheers, Leon
    Optix Photographix
      Originally posted by Snaga
      13ish lts... that's about right for what I was getting........ b4 all the extras went on
      If it's ALL h/way driving you could probably expect a little better but with around town as well it sounds right.
      But it's only lifted to 15ish with all the extra weight and meatier tyres.
      Yeah, I'm quite happy so far, but there's always room for improvement. Best I got on a tank so far was 7.8km/l (12.8l/100km). I'm sure the little bit of lift has a small influence, as well as the 265/75/16 Dick Cepek F-C II tyres. I have not checked the odometer yet, but the speedometer is now indicating the same as GPS with the slightly bigger tyres than standard.
      It should also go for a 160,000km service soon, which might improve consumption by about 0.00001 l/100km... :lol:
      98 GXL 3.4V6
      40mm Toughdog Suspension Lift
      265/70/16 Bridgestone D694
      16x8 zero offset steel wheels
        I don't know how many litre's per 100k's mine uses as I've never sat down and worked it out. I get around 330-360 k's out of the sub tank and around 500-550 k's out of the main tank, this is generally every day around town driving with a bit of highway and a bit of beach.
        Alan
        99 GXL V6, 2" EFS suspension lift, ARB winch bar, Mickey Thompson ATZ 4ribs, ARB on board compressor,front and rear airlockers, Hella 4000's, ARB ally roof rack, Ausguard cargo barrier, Safari snorkel, t max 9000lb winch, t max recovery kit,105 amp/hr Thumper dual battery system, Waeco CF50 dual zone,OZtent RV5, ERPS rust protection, PP stickers.
          I just read a thread about the fuel return to the other tank. This may explain a few things. Will have to do a 2 tank fill test to get accurate fuel economy figures.
          cheers
          David
          2013 FJ Cruiser
          265/75r17 Cooper ST Maxx, Rear locker/A-Trac/Crawl
          Losi Comp Crawler for the really rough stuff
            cheers
            Yeah, the only way to get an accurate measurement is to fill both tanks till full. Drive around recording any amounts filled and then tally all amounts after the next total fill and the kilometres since the last total fill. I fill to the top every time as I do so many k's each week so it makes keeping track of fuel figures nice and easy.
            Cheers, Leon
            Optix Photographix
              Normal driving around Brisbane I get 600KM on the main and 300KM on 3/4 of the reserve. Estimating around 1000KM for fuel load.
              Highway is 700KM and 450KM per tank. Estimate 1150KM +
              I drive the Prado easy on the road. I am about to drive Brisbane to Sydney without fuel stops and 2- 3 days driving within Sydney.
              I have recently serviced the vehicle and changed from the standard NGK plugs to the Bosch spark plugs. I have roughly worked out I am getting 7KM/l since the change. This includes city driving and 4 hours offroad in low range. I will be testing the results over the next full tank load.
              Talking to some other Prado only recently, one is getting 10-11L/100km on his economy. He was using a good quality 15W/40 oil and K&N filter on a Grande VX.
                Hi bmurray2250, are you running a 4 or 6 cyl petrol or a diesel ?
                  Hey guys,
                  (3.4 V6 Auto on 91RON)
                  Got the calculator out at the servo here the other day.. Combined suburbs / 80-90kph freeway result was 14.4 l/100kms. It's actually better than I anticipated, but we'll try again after I pull that bloody flap out of the main muffler! :twisted:
                    I have a Prado 1998 V6 3.4L Petrol with BFG AT tyres, 2" lift, bull bar, etc.
                    I use a K&N filter and have been using 15W/40 oil in the vehicle for the last 8,000KM. Recently did the service which included, oil change (15W/40 oil), greasing the CV's and then changing the plugs from the standard NGK to Bosch.
                    L/100KM
                    15.662
                    13.693
                    13.613
                    14.690
                    11.837
                    13.843
                    15.424
                    17.861
                    14.780
                    18.943
                    25.756
                    17.036
                    16.727
                    12.967
                    13.729
                    16.545
                    17.056
                    13.854
                    14.018
                    13.605
                    16.034
                    15.423
                    15.097
                    15.928
                    15.296
                    15.326
                    14.580
                    22.604
                    20.631
                    16.152
                    16.962
                    17.560
                    15.382
                    15.352
                    The high fuel use over 17l/100KM include offroad, beach driving and with a trailer. I am averaging around 6.5KM/l which isn't to bad when Fraser and Moreton Island trips in there. Present fuel load which is coming up a refuel on Tuesday is giving good signs. Main tank: used 45l (roughly) for 250KM which is bad. Changed the spark plugs just below half and then went bush of a day. Drove over the great diving range to get to the club meet. Ran out of fuel on the main tank at 574KM (which include 4 hours of low range driving). I just about half on the aux tank (I have the 60L Aux) and have 780KM. I can tell you I have imporved my fuel since the plug change and have more power.
                    The next 2 loads of fuel will be interesting
                      That range of figures looks familiar... glad I'm not the only one who has the occasional +20l/100 moments.
                      Cheers, Leon
                      Optix Photographix
                        well the last 2 full tanks(both Tanks Full) , the first before i replaced the airflow meter and the second after, first tank, Canberra to Griffith return. the second tank was Canberra to sydney return.
                        15.6 first tank, 13.8 second tank. Pretty happy with the second tank.
                        2000 GXL. 3.4lt V6, ARB Sahara Bar, IPF's, foglights, 2 inch lift (OME), Cooper ST's 265/75/16
                        GME 3600 UHF, Nokia CK-7W car Kit
                        Soon to have HD Towbar and Snorkel. Maybe even lockers!
                          Getting 7KM/L (14.2L/100KM) in the city and 6.9KM/L from the Jenowen Hill (includes small amount of highway and city driving). The Prado is running the best I have seen since recording the fuel usage
                          • #28
                            The K&N air filter is good as long as you maintain it correctly. The difference in performance and economy between the standard and K&N was zip which may change when the snorkel is fitted in the next few weeks. I talked to other 4x4 owners and mechanics that I know and they said it should help the breathing of the vehicle and they had changed to the K&N. The cost of the OEM filter for 3 replacements equal a K&N with recharge kits. Comes down to your perferance but I feel I made a good decision but only time will tell.
                            • #29
                              Hey again dudes!
                              I'm now on my third fill of 95RON Premium and fuel consumption's dropped to 13.6 l/100km (from 14.44 on 91RON).
                              Still hasn't offset the cost yet, I calculate I'm getting 7% greater efficienct but spending 8% more on fuel.
                              Can't win eh!
                              • #30
                                Recent fuel usage has improved and besides driving in Gold Coast traffic and off-road trip my Prado is showing good ecomony running standard unleaded fuel. A friend also with a Prado V3.4 has changed back to standard unleaded from E10 and getting much better fuel returns. Recommend to clean the MAS which is between the air filter and engine if it hasn't been done for a while, it will cause issues with the fuel use.
                                L/100KM Type of driving
                                14.463 City driving and Jenowen Hill 4x4 trip. Service done with new spark plugs.
                                14.264 City driving
                                14.208 City driving and short trip on highway
                                12.410 Snorkel Installed - Hervey Bay trip
                                15.423 Gold Coast, Gatton 4wd trip and city driving and cleaned MAS
                                12.689 Esk, Kilcoy and city driving
