Hi guys, I've done a bit of a search but couldn't locate anything on this... I'm wondering if anyone can advise of where the upstream O2 sensor(s) is/are? I've looked the exhaust over from the manifold and down a bit under the car but can't seem to find it.
The car's losing power and running a bit rough when driving up long steep hills at speeds and it reduces the car to 50/60km'h max until I hit flat roads again. All other forms of driving including accelerating hardish when entering the highway are fine. When the engine begins to struggle and die a bit on steep hills the engine light comes on and remains on until the car is switched off.
I replaced the rocker cover gaskets, spark plugs and plug seals a couple of weeks earlier and that job went without hitch, so that can be ruled out. I'm thinking the upstream oxygen sensor is due for renewal. I'll get a diagnostics check done by super cheap auto soon and will get them to print the fault codes for me. That will hopefully tell me which sensor it is throwing the fault if it is in fact a sensor, or will let me know what the cause is. But in the mean time I'd like to check the sensor and clean it to see if that improves things when driving up a long steep hill which I have to do every day to go to work.
Just in case people suggest the following as a possible cause, I believe they can be ruled out. Air filter - it's clean. Fuel filter - it's only been in for 25,000km. I don't think it's spark related as it only happens on steep hills. I don't think it's fuel or air related. I lent a thought to it being the catalytic converter but I really don't want to remove it and clean it as a weekend project if I have the choice. I will if I absolutely need to but have you seen those rust seized bolts and nuts
Plus an issue with the cat is almost always caused by something else creating a knock on effect, like a faulty O2 sensor.
I look forward to your replies.
