Squeak Noise :S
  • Squeak Noise :S
    When the car is cold and past 2nd gear it develops a squeaking noise i cant pin point it. It stops when i accelerate. coasting in 3rd and 4th at 40-60km it does it- But not on the highway. Almost sounds like a belt or a pulley slipping. Anyone else had this problem and what was it. Cheers Mass
    1999 Prado Snowy 265/75/16 Mickey T's ATZ 4RIB, Uniden 80 channel CB, 2" EFS with PolyAirs, PP Rear table, JVC Bluetooth deck.
    Dry uni-joint? I know other members have had issues with squeaking noises because of a hard to reach/see grease nipple on the Double-Cardan joint of the rear prop shaft.
      Mate i have the exact squeak also ! Same symptoms , nothing at idle or when revving in the driveway so very hard to pinpoint . Stops when i accelerate and is noticeable when i lift off the throttle at 50 - 60 kmh .very frustrating will check the unis .
        Hi Mass. By the time U-Joints get to the squeaking stage, you can generally see brown fretting powder around the crosses. The U-Joints if stuffed will also usually squeak when idling along the flat in all gears. A quick squirt of lube in all joints and you may eliminate this possibilty anyway. Cheers.
        2005 100 Series Landcruiser. 4.2 T/D 5 speed auto. LTD c/w AHC/Leather etc.
          Grease all 4 unis. It is hard to find all of the nipples. I do it this way, put the car on a nice flat surface. Take it out of gear and take handbrake off. Get under it. Start at the back uni, grease any nipples you can see, then, whilst under the car, push it forwards or backwards until the uni turns and the other nipple becomes visible and grease that one. Do this for each one. Do not miss the nipple in the guts of each uni, this will be the one that is most likely causing the problems.
          Oh, and pump grease until the fresh stuff comes through. wipe off excess with a rag otherwise it will fly off as you drive and make a mess under the car.
          Westy
          2001 VX 3.4, Dual Fuel, TJM Nudge, IPF Spots, Uniden UHF, Ming Tint, Dust deflector, side steps, Bridgestone D694LTs. [url=http://www.fuelly.com/driver/Westy90/prado][img]http://www.fuelly.com/smallsig-metric/68370.png[/img][/url]
          [url=http://www.postimage.org/][img]http://s1.postimage.org/gu8j7rlw/prado_avatar.jpg[/img][/url][url=http://www.postimage.org/][img]http://s1.postimage.org/guigfukk/08062010_001.jpg[/img][/url]
            It can also be the front two bash plates rubbing where they bolt/clip together, mine was doing this, still does it in the odd occation.
              TIme to pinch the grease gun from work and get dirty- Thanks for the tips guys. Crooza, It you may be on the money that is also what it may be come to think of it, Now how to rectify.... Hopefully after greased uni and had a look at the bash plates it disappears. *Fingers Crossed* Thanks all for your kind help. Mass
                Hi Mass. Regarding greasing universal joints. Take a bit of care that you don't overgrease. This is a case of less is best. Once you have settled into a routine (every service perhaps) one pump in each nipple is plenty. If you get too keen, you can unseat the seal and crap and water can get in. The hydraulic pressure generated by these grease guns is quite staggering and they are used to tension tracks on bullies and diggers. Croossa was right about the bash plates - mine was noisy after some plonka at a tire shop used it to jack up the front. Cheers.
