Can anyone tell me if the main fuel tank from a 120 (the one inside the chassis rail on the passenger side) will fit under a lwb 90? The UK 90's only come with the main rear tank, and I want to fit a sub-tank.
120 tank in a 90 lwb
No it will not fit, if you want extra fuel storage, just buy an aftermarket tank, there are many makes out there specifically for the 90 series, I think you can get them up to 150lts.97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Wanna buy my aux tank? Maybe I can then justify a custom one to suit my bodylift!!
Oh wait, you have a bodylift too.. perhaps you should pay for a custom one. The stock ones hang quite low.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Originally posted by fridayman View PostWhat benefit would you get from a custom tank over your current setup with auxiliary tank? I will probably look at stock setups too because that might be the most straight forward when it comes to plumbing it in.
Try looking here http://www.longrange.com.au/navtankmodels.html#toyota97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
4WD Systems in Adelaide have a long range tank for the 90 series which is 155 lt's. So that takes the total capacity to almost 225 lt's
http://www.4wdsystems.com.au/index.php?id=25Our 6 year old and 3 year old try their hardest to make sure there is no time or money for the other baby
Originally posted by letsgoplaces View Post4WD Systems in Adelaide have a long range tank for the 90 series which is 155 lt's. So that takes the total capacity to almost 225 lt's
http://www.4wdsystems.com.au/index.php?id=2597 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
I'd have to agree with croozza though, for most people with a single tank, it'd be much less work to just increase the main tank's size.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
