Radio Antenna 1998 ser. 95 VX
  • Radio Antenna 1998 ser. 95 VX
    How do I check if the signal wire is connected to the back of the radio?
    Or should I ask if I can check if its connect without dismantling the whole dash?
    I think you would have to pull the radio out mate. It isn’t that hard.
    Are a few threads here about it.
    But basically, remove the ashtray, undo the screws in there that secure the middle fascia panel, and then working from the bottom; ease the fascia panel off the retaining clips. The pull the radio, however remember that it has the anti theft pin code security feature.
    What is the problem, no radio channels, and just white noise ?
    If it is a jap import their FM is in a different band than that used here, can get a frequency extender and fit it.
      Thanks, the antena does not go up.
        If that is the case, then just buy a new mast, plenty on ebay. http://www.ebay.com.au/itm/Auto-Ante...item1e6b1235ed
        Just remember that when you fit it, you need to ensure you have removed all of the old broken bits inside.
          I thought there was a blue pill for that?
