I have an 1996 Toyota Prado, It is my First Prado.
I have owned other Vehicles with Dual Fuel Tanks and have not had this feature, 70 and 80 series Land cruisers, Pajero
The manual Says (attached) that when you drive on the Main tank it Puts fuel in to the Sub tank to force you to use the sub to keep the pump lubricated. (this makes sense)
1st Question) I had just over half an tank of Main when I decided to swap it to sub, I am down to half a tank on Sub, at the same time the Main has dropped down to a Quarter, with out me running on the Main tank at all.
Is this Normal?? seems like it is using from both tanks!
2nd) Does any one know how much gets pumped in to the tank from the other (EG 5lts for ever 20ltrs used
3rd) Can I Disable this feature with out buying a new solenoid, as I like a Sub tank to be a Sub (Reserve, Emergency etc)
4th) When the Sub is Full, and you are running on Main am I looing fuel on the road or what?? where is it going when its pumping it over?
Manual
https://skydrive.live.com/redir?resi...8BA22776%21281
4x4
https://skydrive.live.com/redir?resi...8BA22776%21280
Manual
4x4
