What did you do to your 90 today?
  • Are you getting the water pump done as well...?
    98 GXL......
    My build up
    [i][url]http://www.pradopoint.com/viewtopic.php?f=38&t=8948[/url][/i]
    • Yep.
      Mint 1999 GXL Prado - Work in progress
      • 1200 ? you wouldn't do it yourself Darren ?
        2018 GXL 2.8 1GD,
        • I was quoted $1100 for timing belt kit, thermostat and water pump. Will be abit more as i added a few other small jobs i wanted done.
          I could of done it my self, but seeing as its the wife's daily drive i wanted it back quick. I would of taken all weekend and more to do it myself. Plus i think there is a few tools i dont have to do it.
          Well it is staying over night as the day ran out. Its all but done. just all the little fiddly things and checks to go. No surprises, parts where getting on but still within serviceable limits.
          • Yikes! $1100!
            No special tools required unless changing the camshaft seals.
            • light bar fitted today
Name:	light bar fitted.jpg
Name:	light bar on.jpg
              [URL="http://www.pradopoint.com/showthread.php?35754-1997-PRADO-GXL-(lap004)"][SIZE=5][FONT=Book Antiqua][CENTER][B][FONT=Century Gothic]MY 95 SERIES PRADO GXL.[/FONT][/B][/CENTER][/FONT][/SIZE][/URL]
              • Originally posted by LAP004 View Post
                [ATTACH=CONFIG]20870[/ATTACH]
                [ATTACH=CONFIG]20871[/ATTACH]
                Massive difference eh? I fitted up my KORR XDS500 the other day and am now contemplating upgrading my HID spots or just ditching them all together as currently, I can barely tell if they're on or not.
                • Originally posted by RanJ View Post
                  Havent had a chance to use it at night yet but on dusk the hole yerd was bright white. Ill take some photos tonight.
                  • love the light bars!
                    I forgot the switch was on the other day and flashed some old dear who was doing 85 in the 100, bet she got a fright lol, turned them off quick smart after that lol
                    SAM
                    • Originally posted by juc33_prado View Post
                      SAM
                      Loving mine so far. Ill do some range test tonight and post photos. To compare headlights high beam all and just light bar.
                      Hahah she may have decided to speed up after that.
                      • Hay RanJ, im looking at the same bar as you. How easy was it to fit up and did you use one of their wiring looms?
                        • Wrapped some heat shield around the second battery under the bonnet.
                          Changed the spark plugs, found out that whoever changed them last time used the wrong gap size plug... useless dealers...
                          SAM
                          • FITTED my front suspension spacers tonight.fitted the 25mm spacer which is meant to give 50mm.
                            my before was lhf 715 rhf720 now at lhs 765 rhs 770. overall very happy with the extra hight.
                            • How does that work? What spacer are you using? Spring pad or strut? I bet they were a bitch to put back in haha.
                              Last night I pulled out my old and flogged sway bar link bushes and put in some new shiny red ones. Instant difference this morning when my daughter (L Plater) didn't show daylight under the inner rear wheel going around a roundabout near our house.
                              Me personally? Didn't notice a difference haha just piece of mind.
                              Ordered new pads and rotors all around. $750 for slotted DBA fronts, standard DBA rears and Bendix 4x4 pads all around. Then new struts. Waiting for a new 5 tonne press to arrive and I'm going to do the front control arm bushes.
                              Hope I don't lose too much ride comfort. It's all ready becoming a bit too stiff for road use.
                                they are a strut spacer, so u pull the strut out in with top still attached. then using the top bolts that hold the top in to the upper suspension brackets, to bolt the spacer on then. bolt the hole assembly back in. did require unbolting the lower ball joint so i could leaver the lca down to get the lower strut bolt back in.
                                while fitting the spacers i found i snapped a sway bar link pin at some stage
