Can anyone help me with the switches for fit out of a lightbar and driving lights. I have found some on ebay from Newpro-tech and also Air on board and these are made for oem replacement into existing blank sockets in the 120 series, I have asked the sellers the question and have come back with a NO and only for 120 series. Thing is when you see the examples of their fit out pics in Hilux and Cruiser, the switches look exactly the same as in the 95 series. At 20-25 $ a piece I don't want to buy and then find out negatory for fitment. The switches are the same as the push style. What have everyone else used for their lighting acc? Had not really wanted to go in for the rocker style when push style looks so much better.
swiches for lightbar and driving lights
Air on board push style work for me. . Slot straight in . The carling style rocker switches I've used all need filing to fit. Waiting on blue background for one to come in so I can get one labelled winch . I think it's a 8510? From memory
Matt2008 120 GX D4D with a few extras
Rig build here
Matt,Originally posted by Mattfunk 120 View PostAir on board push style work for me. . Slot straight in . The carling style rocker switches I've used all need filing to fit. Waiting on blue background for one to come in so I can get one labelled winch . I think it's a 8510? From memory
Matt
I believe Benzbaby has a 95 series Prado.
Scottkz........That's what I don't understand, if the 75 series fits, newpro say they do fit the 75 series Cruiser and the 120 Prado but not the 95 and then the Air on Board say they don't fit the 75 series but do fit the 120 series Prado, but have the exact same dimensions. The A/C and demist push button outer dimensions on the 95 series are 32x18 mm, Air on Board say face dimensions of their switches at 39x21 mm.so I could go that path but need to remove material to fit. I will PM the guys at the top of this thread as suggested, thanks guys for your help so far, I will conquer this one.95 series Snowy gxl, tjm colour coded alloy bar, bilstein/lovells, 694 Duelers, lpg.
Just been on Narva website and it looks like I will have to settle for the rocker type, Bummer, wanted to fit horizontal plane to get the switches away from my knees on the 95 series, not really a user friendly place to go mounting switches as you have to look down away from the road to see switches, add to that they really don't look that great compared to the push button type but I am not going to carve up my centre console just to fit the push style, not that I don't have the dexterity required or the tools just fit and finish really.95 series Snowy gxl, tjm colour coded alloy bar, bilstein/lovells, 694 Duelers, lpg.
Someone else recently asked about my switches:
Originally posted by glen_ep View PostOn my right side I have the supplied ARB locker switches which are approximately 21mm x 35mm (rear section).
On the left I have 2 "Narva" rocker switches from a local car parts store, used for ECU mapping & Auto lock up, they're about 19mm x 35mm (rear section).
For both I'm pretty sure I had to trim the hole a little, but the fit is not perfect, so it's easy to pull them out (but they won't fall out).glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
