Intercooler info.....please
  • Intercooler info.....please
    Hi.
    I own a Colorado 3.0Lt TD which unlike the Prado is not fitted with an intercooler as std.
    I was wondering if any of you can send me photos of the intercooler set-up in the Prado e.g. Location, pipe routes, intercooler dimensions and pipe diameters. Any advice on installation and set-up will be great.
    Bosvark
    Hi!
    I would recommend you to download the Toyota EPC.
    <Copyright breach> REMOVED
    There is a guy on the Norwegian LC forum who has fitted a D-4D intercooler on a 3,0td. Maybe you'll get some ideas by looking at the pics http://nlck.no/forum/viewtopic.php?t=473
    KDJ90 -01 D-4D
      Thanks for the info.
      I am a way for a week now but will look into it as soon as I am back
      Regards
        Dimensions: 335mm x 230mm x 60mm
        Inlet 50mm diameter
        Outlet 65mm diameter
        [size=1]
        2007 FJ Cruiser 6M/T[/size]
          Hi,KZJ90
          Thanks for the photo and the dimensions.
          How much space is there between the intercooler and the bonet?Was just wondering about the air flow.
          Do you think a LC120 intercooler will fit straight on?
          Will start snooping around for bits...
          Regards
          Bosvark
            Regards
            Hi there Bosvark,
            Did you manage to get hold of the information you needed for the intercooler setup for your rig?
            Also, in your travels, did you find anyone who supplied intercooler upgrades for the Colorado/Prado?
            I ask, as I'm on a bit of a mission of late, to find a suitable upgrade for the little intercooler in my Prado, the joys of the internet allow me to spread the net a tad wider, so any info you may have would be greatly appreciated.
            Paul.
            ~~Brand, Schmand.. It's ALL Good.~~
            2002 Prado 3.0 TD, 2" Tough Dog 9-stage Adj, 5Sp Manual, 2.75" Mandrel pipe, AirTec snorkel, K&N.
            My Shed :[url]http://www.pjrobinson.com.au/MyShed[/url]
              Hi MarvinPrado95
              I haven't find any thing yet, here in the UK any thing not Land Rover is difficult to find/get hold off.
              I spoke to a company, Brunel Performance, they said they can build one to any spec, which sound good but as all ways there's a price to it as well.
              I am looking to find an intercooler from a d4d; pajero/shogun, patrol or nissan narvada p-up.
                Hi,KZJ90
                Regards
                Bosvark
                There is about 7 cm. And you can see 120-series intercooler fits, like Soll told: http://nlck.no/forum/viewtopic.php?t=473
                I have now 11 cm high water-intercooler under my hood without problems, but I have 5 cm bodylift.
                Check this also: http://forum.buschtaxi.org/galaxyq-baut ... 8a8feaf518
                [size=1]
                  hey i did a change from the 1kzte engine which is what you currently have and put in a D4D which off course is awesome !! regarding the intercooler they are the same you will have no problem fitting on as the engine block head is still the same just mounting points in differnt spot but easy to mount brackets etc
                  good luck and have fun !!!
                  cheers
                  90 series Prado with a D4D purring under the Bonnet !!, Catch me if you Can !! taa
                  Shes Loaded with air compressor,
                  2in top dog adjustable shocks and coils, 31 in tyres, Arb Bullbar and Warn winch, cargo barries and more to come when the Interest Rates comes down
