Hi all,
I picked up a 98 Prado a week ago to be my fishing car
However I'm guessing someone before me had it on gas and then someone took it out as it only has 1 tank (side - not sure on size) as you can imagine this car chews so need the 2nd tank. Currently that side tank is showing on the main fuel gauge but after doing 80kms it's gone under 3/4 fuel.
Is that side tank the sub or main from factory new? I'm pretty sure I've found a rear tank and straps at the wreckers but after any advice at what I may need more than just tank, hoses, straps?
Also when I turn sub tank off and green light goes off car cuts out, so confused with that, main fuel gauge shows current level sub tank gauge shows 0 yet green sub light is on.
Sorry for the long post but after advice cheers
