My faithful 1999 KD-KZJ95W-GKPST-R Prado is getting a bit hot under the collar
A couple of days ago whilst driving and adjusting the temperature lower in my 90 series I heard a repeated mechanical ‘clicking’ noise down and forward of the passengers seat close to the centre line of the cabin. Pic shows roughly where it sounded to be coming from. The clicking occurred when selecting temperature about 22 degrees and lower. It was as if a small motor was trying to drive something that would not move. The clicking stopped after a short time. The temperature of the air did decrease a bit but not down to anywhere near the 18 to 20 degrees expected. It has been working fine for years with no issues in either manual or auto and with aircon selected on or off. I therefore think the failure is a stuck flapper door that controls the warm air being supplied to the mixing chamber/plenum that is not closing off enough and so letting too much warm air into the mix.
I have a basic understanding of climate control as follows:
We are supposed to head away later today for a trip to the North and do not need warm air (lovely summer here in NZ) at all so perhaps I could disconnect the warm air supply to the mixin chamber as a stop gap measure until I have time to pull it apart. Could someone please give me a rough idea what to look for or where to look please. A guide using the supplied pic would be of great assistance. Many thanks, Zap.
- Climate control is achieved by mixing warm and cold air and then directing to selected areas/zones of the cabin.
- Water from engine cooling system circulates through a heat exchanger/radiator in the left forward cabin on the rear of the firewall and is the supply of warm air to climate control.
- The aircon compressor provides cold air to the climate control. The operation of the compressor is governed by the A/C switch - you can stop the compressor supplying cold air to the system if desired.
- A mixing system of flapper doors combines the two airstreams to supply cabin air at the selected temperature on the rotary selector between 18 and 30 odd degrees. I THINK THIS IS WHERE MY PROBLEM IS.
- This mixed air is then sent to the user selected zone using the MODE push button (= AUTO is deselected) or is directed to cabin zone based on mixed air temperature relative to ambient temperature ( = AUTO sends warm air to footwell or cool air goes to face vents.
