Just wondering good spots to put recovery points on my rv6 . I have a steal arb bull bar so was looking at mounting one on there and on the back i have a gen toyota tow bar can u mount them off that ?
recovery points
Re: recovery points
Wazza,
Use a hitch receiver on the rear like this (about $50):
Check the body and chassis threads for front points. There are heaps of threads on this topic already.
Chriso[COLOR=blue]Current rig - 150 GXL D4D Auto TJM bullbar. Airtec Snorkel. ARB Underbonnet Comp.
Previous rig - 02 TD GXL.[/COLOR]
Re: recovery points
Originally posted by Wazza78Just wondering good spots to put recovery points on my rv6 . I have a steal arb bull bar so was looking at mounting one on there and on the back i have a gen toyota tow bar can u mount them off that ?97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Re: recovery points
I have 2 x tow/recovery hooks (Bushranger brand) bolted with high tensile bolts to the chasis. I have used the 2 bolts on the left and right side that bolt the bullbar on. I needed to get longer bolts to replace the existing ones. My intent is to use a bridle recovery from these 2 points if I get stuck. I will be replacing the hooks with a couple of "Lukey's" recovery points, I just have to measure the bolt to bolt distance so he can confirm which set fits the RV6. On the rear I just a hitch Bushranger rear recovery hitch with a 4.5t Bow Shakle.[b]2000 Prado RV6[/b] ~ TJM Type 15 Steel Bullbar ~ Uniden 400SX-RM & GME4702 Ant ~ Front Tow/Recovery Hooks ~ ARB Recovery Kit ~ ARB CKMP12 Air Compressor ~ DIY Rear Door Trim & Table ~ Extended Diff Breathers ~ Safari Snorkel ~ Wireless Reverse Camera ~ Iron Ox Full Length Roof Rack ~ Looong Wish List ...
Re: recovery points
On the front chassis rails the car will normally have tie down points from when the car came over for Japan, just unbolt them and any recovery hook will normally just bolt on in the existing holes, I have put two on the front doing just this.Hers: 2009 Hilux TD with lots of goodies........
His: 1998 V6 GXL Manual Cooper ST Maxx, Bullbar, lift, etc
Re: recovery points
I bought a 2001 GXL a few weeks ago and am struggling to find the right advice on the recovery points.
I have spoken with both Outback Ideas and Mannam Motors and both have said they have never made or installed recovery points on a 90 series.
My tie down points are bolted to the chassis and then connect across to the Bull Bar (Toyota factory fit) and it is part of the structure holding the bull bar on.
You can’t take these tie down points off as they hold the bull bar and there are no other bolt holes that would allow you to attach hooks.
I’m stumped!
The tie downs are all in 8mm plate steel.
Any suggestions?
I also have a factory fitted Toyota tow bar rated at 2500kg braked and 750kg unbraked and with the sticker that says ONLY TO BE USED FOR TOWING APPLICATIONS.
Of course it uses any bolt holes in the chassis that would allow you to attach a hook. Am I an idiot to assume that the tow bar will take a Bushranger recovery hitch rate at 4.75t?Michael
[b]2001 Prado GXL 3.4l [/b]: Toyota alloy bullbar ; Toyota tow bar; Bushranger recovery hitch; Mickey Thompson AZT 4-Rib; Mega Grunt compressor; ARB speedy seal kit; Safari Snorkel; Tough Dog 2" lift kit, Uniden UH015sx UHF; Reversing Camera;
Re: recovery points
Originally posted by Michael63I bought a 2001 GXL a few weeks ago and am struggling to find the right advice on the recovery points.
I’m stumped!
Any suggestions?
The tow ball should be a removable one (NEVER recover using the ball). As per the first post in this thread and my above post, get yourself a hitch recovery point to slot into the receiver. About $60 - $80 from any ARB shop.
If you need a photo let me know and I will try post one after work this evening.[b]2000 Prado RV6[/b] ~ TJM Type 15 Steel Bullbar ~ Uniden 400SX-RM & GME4702 Ant ~ Front Tow/Recovery Hooks ~ ARB Recovery Kit ~ ARB CKMP12 Air Compressor ~ DIY Rear Door Trim & Table ~ Extended Diff Breathers ~ Safari Snorkel ~ Wireless Reverse Camera ~ Iron Ox Full Length Roof Rack ~ Looong Wish List ...
Re: recovery points
A picture would help - I am having trouble visualising how the Bushranger Hooks would sit against the tie down bracket.
I know specialty fastners so will be able to sort the rest out.Michael
Re: recovery points
Rouge Aussie - some pictures – I haven’t figured out how to upload yet
http://i1121.photobucket.com/albums/l50 ... eDown1.jpg
http://i1121.photobucket.com/albums/l50 ... eDown2.jpg
http://i1121.photobucket.com/albums/l50 ... eDown3.jpg
The first pic shows the tie down point from one side, the second is the tie down point from the other side with the bracket extending up to the two bolts attached to the bull bar and the third shows the bolts from underneath.
Is this the same as yoursMichael
Re: recovery points
Originally posted by Michael63Rouge Aussie - some pictures – I haven’t figured out how to upload yet
EDIT: I am actually wondering if the tie down points you have aren't sufficient enough for recovery??? I have a factory tie down HOOK that was ... well to be honest ... pathetic, and any recovery strap would have slipped off. If in doubt regardless, the bushranger hooks are only about $25 each + cost of bolts and Lukey's points are $88 a pair + cost of bolts. So not a huge outlay regardless for peice of mind.[b]2000 Prado RV6[/b] ~ TJM Type 15 Steel Bullbar ~ Uniden 400SX-RM & GME4702 Ant ~ Front Tow/Recovery Hooks ~ ARB Recovery Kit ~ ARB CKMP12 Air Compressor ~ DIY Rear Door Trim & Table ~ Extended Diff Breathers ~ Safari Snorkel ~ Wireless Reverse Camera ~ Iron Ox Full Length Roof Rack ~ Looong Wish List ...
Re: recovery points
Looking at the Lukey's they seem to have the same thickness plate as my Tie down points but I'll see if I can google that.
I'll see if I can find out from Toyota what grade steel they are made from....won't hold my breath but it might be strong enough.
The problem is, because the tie down point and the bull bar bracket is a combined unit, the bull bar bracket gets in the way of where you would mount the Bushranger Hooks or the Lukey's
A photo would helpMichael
Re: recovery points
Hi Michael,
Just had a look at mine (factory bullbar as well) which look similar to yours except mine seams to be cut off at the bottom (orange line down) and two holes drilled. And the recovery hooks bolted on sideways. I think your right about how they may not fit on your setup??
Danrex
Re: recovery points
Danrex,
thanks - I might have enough room to get bolts through from the inside which means I can mount the hooks on the outside.
I'll check it out tomorrow
MichaelMichael
