95 series OEM spring measurements
  • 95 series OEM spring measurements
    Gday.
    I'm looking at speccing a set of custom springs for a 2001 95 series. It's a poshpack diesel manual but I doubt there'd be any difference to speak of among the variants.
    What I need is the specs of the original springs. If anyone has a fairly fresh set lying around the garage, could you please measure for me the following:
    1. Free length
    2. Outside diameter
    3. Rod (material) diameter
    4. Number of coils including the fraction of the last part coil
    Thanks in anticipation. Your hard work will be rewarded with beer when you get to Alice.
    G.
    150 D4D GX with big tyres, TPMS, Tracklander, GME, Safari breathing straw & super soft squishy custom rear springs.
    Gday Gordon, I have a set 2002 95 series. I'll have the measurements for you tomorrow afternoon. Front, rear or both?
    Cheers Peter
    02 TD Auto Advantage.
    Light force 140's,Dual batteries with redarc,Volt meter for aux.battery,300w inverter,Rotronics
    low coolant alarm,Kings springs,70 Ltr evercool fridge freezer,Rear power outlets for fridge,
    Garmin quest GPS,Fire ext,Beaudesert exhaust,Removeable rear floor,GME TX4200 UHF,
    Alloy bar,Tow bar.
      Um, both please?
      GS.
        Front
        Free length 360mm
        OD 110mm
        Rod OD 15.5mm
        Coils 10
        Rear
        395mm
        145mm
        14.2mm
        8
        Alloy bar,Tow bar.
          Also, if you give Dobinsons HQ in Rocky a call, they have a database of OEM coils and should be able to tell you the spring rate as well as the free length: Ph: +61 (7) 4927 7444
          This is the data I have compiled for the 120 series: http://www.pradopoint.com/showthread...nsion-Database
            Great. Thanks to both Peter B & Peter P.
            GS.
