Hi, dumb question needing answer please.
I've just replaced my rear sway bar bushes and also installed two new links. Each new rear link came with 2 new bushes and 2 new cupped washers in the bag. When I installed them I first slid a washer onto the link, then a new bush, then the chassis, then the second bush, then the second washer, then the top nut...and repeated that on both sides.
Then I looked at the original ones I took off and noticed that I was seeing more washers! One link had 3 washers and the other 4!!
So, what's the correct way to install these please? Am I ok as I am? Or do I need to buy 4 more new washers so that there's a washer on each side of each new bush? (The old ones look a bit shagged)
Any help gratefully received. Thanks
http://store.pradopoint.com/wholesal...1/IMG_0057.jpg
