i have apparently 2inch lift king springs hd rears and comfort fronts but im after hd for the fronts
what are these springs
Hey all,
My ancient dead sea scrolls for a 2010 Kakadu have front coil colour codes as DS = double purple, PS = double brown.
I have not seen the red/green fronts or white/green rears.
I can say that they are definitely Toyota coils.
Nor do I recognise the yellow/brown or pink/white or double blue/aqua or double aqua/pink coils.
Can you measure the inner diameter of those coils to give us a clue!?
OEM coil database is here;
http://www.pradopoint.com.au/showthr...a-4wd-vehicles
Not much use!
Best
Mark2006 GXL petrol auto. ARB deluxe bar x3 HID IPF's, ARB alloy roofrack, ARB awning, BFG A/T, Safari snorkel, Piranha breathers, Pacemaker extractors, custom Ironman 45710FE 436-569mm with Dobinsons 350, custom Ironman 45682FE 383-618mm with Dobinsons 487, Firestone kevlar 60psi airbags, 30mm extended Roadsafe links, AMTS bashplate and recovery points, ABR Flyer with Powersonic AGM.
Could they be off a 200?My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
i typed in 200 series land cruiser springs and thats what they are going by this gumtree add
https://www.gumtree.com.au/s-ad/ashf...ion/1154855405
Whitey
