15x10 rims
  • 15x10 rims
    Hi guys im new here I brought some 15x10 steel wheels but they dont clear the brake calipers on the front just woundering if I space the 25mm will they clear the calipers
    On a Prado?
    15 x 10's, with a 25mm spacer - are you looking for the Monster Jam look?
    Micheal.
      Yea man on a 90 series got a mate whos gona custom my gaurds so they dont rub just need abit of advise about clearing the brake calipers
        I can't see you getting 15's on a 90 series forget about it and get some 16's even 16's don't have a great clearance of the calipers.
        as for your spacer idea by the time you buy the spacers if they exist get longer wheel studs which will break when you least want them too you've all ready spent close to what a set of Dynamic rims will set you back ,about $100 a rim.
        As 15 *10 would end up very close to 33 inch will they clear the guards?
        I have 265 /75 /16 on 8 inch rims (31.5 inch maybe) with 2 inch lift they just clear I can't see much bigger going under a 90 series with out suspension and body lift. I can't see how your mate is going to stretch the guards to cover the wheels
        I got myself some Big Horn Maxxis and was telling my landrover lover mate he said what size did you get I told him 265/75/16 he said I didn't know they came that small.
          I tried fitment of wheels they only just rub on calipers so ive ordered some 25mm bolt on spacers so no need to extend the studs and the only thing the rub on is a seam inside the gaurd and I also have no lift in my truck also running 33s on my 15x 10s
            really? how much stud is left to hold the wheel on?
            Go drive it in a hole to full suspension travel does it hit?
              16" is standard rim size for the 90 series
                It bolts onto the studs on the vehicle anthe spacer has its own studs
                  Does the wheel spacer have the hub-centric ring?
                    Nah have to buy those separate im waiting fot spacers to turn up hopefully I wont need them
                      Do they really fit how did you go?
