I carry two spares normally, one on the Prado another on the trailer. I can use either of the spares on the trailer or Prado. I have another spare I can fit on the roof if required. I also carry an ARB puncture repair kit. Should I carry the third spare at the GTG?
Spare Tyres Required
Re: Spare Tyres Required
Originally posted by D4DI carry two spares normally, one on the Prado another on the trailer. I can use either of the spares on the trailer or Prado. I have another spare I can fit on the roof if required. I also carry an ARB puncture repair kit. Should I carry the third spare at the GTG?Roll on the 2010 Pradopoint GTG
Pradopoint GTG website:
[url="http://www.pradopointgtg.com"]http://www.pradopointgtg.com[/url] (final website location on its own domain)
My Weather Station In Alice
[url="http://www.alicespringsweather.a60.us/"]http://www.alicespringsweather.a60.us/[/url]
My photo website:
[url="http://centralian.redbubble.com/"]http://centralian.redbubble.com/[/url]
Originally posted by D4DThanks guys. Having not done any 'outback' touring before what other spares should I pack?Roll on the 2010 Pradopoint GTG
My photo website:
Originally posted by mavOriginally posted by D4DThanks guys. Having not done any 'outback' touring before what other spares should I pack?[B][SIZE=4]ntp
Originally posted by ntpryceOriginally posted by mavOriginally posted by D4DThanks guys. Having not done any 'outback' touring before what other spares should I pack?Roll on the 2010 Pradopoint GTG
My photo website:
D4D I like you have limited out back experience so am taking it easy and thought the Oodnadatta track would be a nice introduction on the way up and or back
My spares list will be pretty simple
Air compressor
Tyre Guage
Spare belts
Spare hoses
Fuses
Wire
Cable Ties
Basic tool kit
CDMA phone and UHF for communications
I was not going to bother with extra spare tyres just one for the car and one for the trailer all tyres are only 6 months old. I have a tyre mate looking around for an old Cooper ATR carcass for me if i find one i may bring it along and hope to borrow tyre pliers or some other tools i would need advise however as i would not know how to use themDont list all ya mods, you will only be more upset when i get further
Chester,
I think the CDMA phone will work well for a paper weight. Do you mean 3G or Next G? Or have I missed something here?
RegardsDirttracker, (Martin)
Prado GXL '05 Diesel.
[url="http://picasaweb.google.com/mpnaylor"]http://picasaweb.google.com/mpnaylor[/url]
[img]http://i197.photobucket.com/albums/aa48/dirttracker123/DSCF5442-1.jpg[/img]
Guys make sure that you at least have tubeless tyre repair kit so you can plug the holes to keep the car mobile...
Also there are no CDMA coverage around Oodnadatta track.
There are tyre repair facilities in Birdsville, Oodnadata and Mount Dare, which can fix a tyres for you...
As for the second spare - it's a Marfy's law - if you don't take one - you'll need it , and if you do - you won't[color=blue][url=http://www.pradopoint.com/showthread.php?12128-2004-120-GXL-V6-Petrol-Buildup-*Warning-Picture-Heavy!*&highlight=picture+heavy][b]My Prado Buildiup Since 2004[/b][/url][/color]
[b]2004 120 GXL V6 4sp Auto D694 LTs and MTRs with Kevlar (best of both worlds )[/b]
[url=http://www.fuelly.com/driver/lc120man/prado][img]http://www.fuelly.com/smallsig-metric/48063.png[/img][/url]
Sorry i meant next G
UHF (with duplex) is fine for the track. UHF channel info for the track is available from the Pink Road House (Website) or keep an eye on the tourist signs along the track, the nearest stations UHF channel is usually marked on them.
unless you have a high volume compressor i would suggest to take a tube to fit your size tyre as alot of these larger size tyres are quite hard to reinflate as tubeless with low pressure compressors.also the plug will have to be removed from inside tyre b4 you fit the tube and have a tube patch and glue just incase you pinch the tube when refitting the outside bead onto rim.get your local tyre guy to show you if you have no idea .
if you take tyre pliers make sure that you know how to use them as i took a homemade set and found at the time they were needed they didnt work .although im an experienced tyre fitter from way back i ended up using my 2 stage jack with putting my 2 tyre levers under it(because the jack has sharp corners on it) across the tyre and jack down from under my camper trailer to brake the bead .also needed a tyre/bead chisel and 4lb hammer to aid in getting the back bead off.
ive seen on lcool site how you can use your prado/l-cruiser jack under your towbar to jack down onto your bead to brake it-also better to have tried this b4 accually needing to do it in the middle of nowhere...
hope this may help
mick i adelaide
98 gxl 3.4v6 auto
