Well done guys, good to see such an awesome prize going to Benji, I'm sure that swag will see some cool adventures for a long time to come!
2014 pp gtg sponsors
I won the CKMTA12 – Maximum Performance On-BoardARB's maximum performance, twin motor, dual cylinder compressor is sealed for moisture and dust resistance and is designed for Air Lockers, air tools and tyre inflation use.
I really liked the idea of not having to carry a compressor in the vehicle & i was told these twin max performance will blow start a Harley.
Unfortunately the larger unit wouldn't quite fit where I wanted it, so I decided to downsize to a CKMA12 – High Output On-BoardPermanently mounted, this water, dust, heat and shock resistant compressor can be used to activate Air Lockers and will perform a number of other functions with an optional tyre inflation kit sold separately.
Top quality product & I should have done it years ago, save space in vehicle, & quick n easy to inflate tyres. Very impressive.
I know many of you have one of these, but if you don't & are thinking about it, don't hesitate!
Thankx again ARB
Originally posted by Anth120playdo View PostBushskinz are giving us a voucher for a sump gaurd!
This is what I use, 4mm plate steel, electroplated & with good centre support.
Thank you Keiron!
Very very happy with this product.
There are other brands available, many made from 3mm & after a few hits, I find they are very difficult to refit after I remove them at service.
The 4mm plate is so much stronger.
Electroplating holds up much better than paint & looks better also.
It has taken some hits & crunches, but still perfectly flat & square. It has a excellent centre support, I don't see this on all the competitors plates either. Right where it takes a hit, nothing, so check before you purchase.
It had some deep scrapes, but I am so impressed with this item, highly recommended.
Originally posted by Anth120playdo View PostI won the CKMTA12 – Maximum Performance On-BoardARB's maximum performance, twin motor, dual cylinder compressor is sealed for moisture and dust resistance and is designed for Air Lockers, air tools and tyre inflation use.
Thankx again ARB
So I traded down to:
Initially I was concerned going from my Chinese 150lt minute bag job, to 68 lt /min, nevertheless it was free & saved the space so I fitted it up.
Looks bloody good too.
Very impressive, when used with the hose direct without the inflator, it is FAST, the clip on works really well, unlike the ones at the servo.
I use a reliable pencil gauge & simply un clip & check, so much easier than having to hold the inflator or wrap it with Velcro. Seems faster also.
I think the Arb lt/per minute is genuine, and these Chinese ones vary a bit as the arb does the job in close to the same time.
Overall super impressed with the unit, it's performance & reliability. Good value too, I wouldn't have a fourby4 without it.
At Bunnings, you can buy the bottom rubber for stool 4 pack, cap the connection to keep it clean & free of dust & mud, water etc. give the other 3 to your mates & they will be happy too.
Originally posted by Anth120playdo View PostPretty lucky you are, it did end up in yours[B]Tasmania 2015 GTG Committee Member[/B] 2005 Prado Pilbara, Sovereign Bar, Driver & passenger weathershields, UHF TX3220, Spare wheel spaces, Lifestyle rack, Genuine front & midrow seatcovers, Genuine front & midrow rubber floor mats, ARB 47 litre fridge/freezer, Hilux washer jets, BF Goodridge A/T, Radiator protection plate, Dual battery tray and isolator, ARB 2.5m awning, Rhino heavy duty areo bars, MSA rear wheel bin, MAXTRAX
