2015 GTG General Chat
    Good to see you are taking your training seriously for the GTG.
    If it doesn't kill us it will only make us stronger. (Where did you say you got the electric blanket for the CT from Andrew?)
      Target! Normal 240v job, run off the inverter.
        Gee, I hope to have a Prado by then!
        I see you've got another now - I just hope I've got one.
        • Originally posted by Palmer View Post
          I thought you got it sorted? If not give a phone call.
          • Just discovered the big crack under the left inner guard. Don't know if I am going to get this fixed before the GTG.
              Just about, this was nothing to do with the engine though.
              I just wanted a couple of things looked over and sorted out so I can be confident that it shouldn't happen again.
                Good news! Did it end up being an air lock? I've had that happen a couple of times, just at that unfortunate stage where the tanks switch over and you shut the engine down....
                Nothing a prime doesn't fix!
                • Of all the things, it was to do with the power steering. A bit of grunt from a jump from mates Cruiser and it turned over (with bloody awful noises) and then fired fine. From that point on it ran like normal - but no power steer.
                  All good now - it's back and running.
                  • Starting to worry now as bad things come in three and there is only 4 committee vehicles and 2 of them have had issues recently.
                    • We're all sorted now.
                      So, one South of the State, one North of the State - aren't you more or less in the middle!
                        Looks like there is a curse of the GTG... My D4D has started running rough - Injector 3 appears to be out of spec...
                          Still 7 weeks and 4 days till the start to gert it all sorted.
                            Glad I left those issues with the insurance company! Check the SCV as well....
                              SCV was replaced last year, along with the injectors. Should have answers in a couple of weeks.
                              • Just ordered these for the GTG should help in the mud Click image for larger version
