I think you need to drive them both and then make up your mind. I would imagine that later in the year and especially next year they availability of 150 will increase. Lot of leases will have their two years up.
One thing to consider is that they are having trouble getting enough new 150`s out of Japan. That may well be keeping the price up a bit in the second hand market. But if you buy one and keep it long term does it matter?
I thought the 120 was ugly when it came out, not as bad as the 150. But the beast has grown on me.
There is definitely improvements the 150 has over the 120. Some of them may be important to you.
Its stronger body, bigger, but heavier, the suspension was adopted from the 120 but has been modified. Its a safer car to be in in an accident, has bigger brakes and more airbags. More stuff inside from the inverter to bluetooth and its better for rear passengers. The electronic aids are very useful in the bush.
If it was me I would rather get the 150, patiently look for a good one, no need to rush. I think its a better base to start from. Then slowly over time add the mods as funds become available. Mods is always interesting, because what you really need or what you think you need to give you the confidence to go out are often two different things.
I would only be fitting new shocks, something like Bilsteins and then raise it around 25mm with Lovell or King springs. Dual battery and snorkel.
I wouldn`t bother with bullbar or winch. I am not interested in turning the Prado into a mud digging bushpig, its too easy to damage it and I don`t play in mud holes for the sake of it.
I have done 25000km now and the car is rolling a bit more than it used to, seriously considering a set new of shocks and might as well fit springs while I am at it.
Just re-read your first post, may I ask why so may mods?
adamr7
