90 series
Check Dashboard to see if you can grab the outer ends of the dash and move it up and down. http://www.pradopoint.com/showthread...l=1#post506226
KZJ95
Crack in the LHF upper inner guard area towards the rear http://www.pradopoint.com/showthread...l=1#post506224
120 series
Common things to look out for
Cracked dashboard
Rust under rear (cargo) door seal
Sovereign bullbar mount CSE ("recall") – this campaign has now ended late 2013
Inner guard cracking
Crack on rear (cargo) door near hinges
Tailshaft clunk
Evaporator leaking
Cracked fuel filler hose
Floppy or stiff auto gear shift lever
1KZ-TE
Cracked heads
1KD-FTV (Nov 2006 onwards)
Injector issues
Injector seats
Injectors out of range
Clogged oil sump pickup
1GR-FE
Engine mounts
Grande
Rust at the front on sunroof
Tear/leaks on rear airbags due to age
150 series
Inner guard cracking (pre-facelift models)
Tailshaft clunk
1KD-FTV
Injector issues
Injector seats
KZJ95
120 series
Cracked dashboard
Tailshaft clunk
Evaporator leaking
1KZ-TE
Cracked heads
Injector issues
Injector seats
1GR-FE
Engine mounts
Grande
150 series
Tailshaft clunk
1KD-FTV
Injector issues
Injector seats
